Attribute Help
Hello. I am attempting to create package that slices any geometry that is plugged into it. I know how to model in Houdini farly alright, but I am not very good at using attributes. In this particular situation I would like to get the dimensions of the bounding box of the source object and apply them to the tube I am going to use to slice up the object.  I create an attribute to get the bounding box dimensions (using $SIZEX etc) as well as a Copy Attribute node to copy it onto the tube. When I attempt to use the new attribute in a Transform node I get an error. The Transform node has the attribute I created but it gets an error when I try to use it. How would I actually use the attribute I made to adjust the size of the tube?
Slice.hipnc
Edited by PlatinumFishy
