[How to]Switching Values of Transform Node using Ordered Menu
Hello!
I have a transform node which is controlling the Y-translation of an object. I want to make an ordered list menu on top level with three settings - High, Mid, Low and the corresponding values would be -0.3, -0.7, -1.2
I have the menu with the labels but just dont know how to hook them up with the values.
Kindly help
Thanks!
In the edit parameter interface for Ordered Menu -> Menu
Type value on Token and the name for Label.
For example, -.3 for Token and High for Label.
After apply,
Mouse over your dropdown menu(ordered list menu), right click, and choose 'copy parameter'
then go to the parameter of translate Y, right click, 'Paste Copied Relative References'.
After apply,
Thanks for the suggestion! Worked :)
