find shutter open and close
Thanks for the quick reply Tomas!
If I try that with
currentF = 5
shutter = 0
shutteroffset = -1
Then I get
shutteropenF = 5
shuttercloseF = 5
It seems like the scaling of shutter is kind of reversed, where lowering it shouldn't change shutteropenF and should bring shuttercloseF closer to 4 (keeping the other variables unchanged)
Does that make sense?
not sure what you expect
if shutter is 0 then it opens and closes in the same time, and since 5 is your current frame 5, will be your shutteropenF and shuttercloseF, regardless of the shutteroffset, so to me it seems correct
EDIT: oh, maybe you expect shutteroffset -1 to always start at previous frame and shutteroffset 1 to always end at next frame
well, that's not the case since:
shutteroffset -1 always ends at currentF and goes from currentF - shutter
shutteroffset 0 goes from currentF-0.5*shutter to currentF+0.5*shutter
shutteroffset 1 always starts and currentF and goes to currentF + shutter
in other words the same way as the equations  posted previously
Edited by anim
