Federico Posted April 25, 2016 Share Posted April 25, 2016 Hi guys, i'm starting to explore the destruction module. I started with some sidefx masterclass and some tutorials. Right now i'm following the tutorial of german de benito about a road destruction (lesson 5) and i'm stuck with a problem related to the for-each node. I'm using the for-each node to create a proxy geometry for every piece of the dynamic geometry but for some reason the for-each node counts the geometry as one. In the first two screenshot you can see how it should supposed to be, the third screenshot it's my current situation. I don't understand how he can visualize only one piece in the viewport, at the beginning i thinked that it was some viewport settings because in the end ,visualize the geometry as one, didn't give me any problem with the road creation. Any suggestions? road.hip Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 25, 2016 Share Posted April 25, 2016 If you open Geometry Spreadsheet and inspect names, you will see that all pieces have same name. Place the "facet1" node below the "assemble1", to generate names properly, or use foreach per-primitive. 1 Quote Link to comment Share on other sites More sharing options...
Federico Posted April 25, 2016 Author Share Posted April 25, 2016 Thank you, it worked perfectly. Quote Link to comment Share on other sites More sharing options...
