Scatter SOP
I'm using the Scatter SOP on a poly mesh (see the monkey rig in the WIP forum) to create points to copy hairs to. This is dependent on the point normals. Is there a way to have each point created by the Scatter SOP inherit the normal from the polygon on which it is located or the nearest vertex? It seems that the generated points don't have normals by default.
hey djpeanut
the attribtransfer SOP could solve that,
u have to declare the N variable on ur base poly obj and ur scatter object before sending it through the sop.
Set the varible to N under point.
under the conditions, theres a kernel radius and max sample count, that should solve that prob.
hope this helps
all the best
aracid :blink:
