IPR doesn't render shadow maps
I'm using a light with Depth Map Shadows, but the shadow maps of the light doesn't show up on IPR/Render View render correctly, just show up nicely if I render the image to disk using the ROP node.
No matter what I do, IPR/Render View is showing the Ray-Traced shadows type instead of the Depth Map Shadows, even If I change the shadow type to Depth Map Shadows in the light: Shadow > Shadow Type. (Please see image attached).
Any idea why IPR/Render View is showing Ray-traced Shadows instead of Depth Map Shadows?
Thanks in advance!
