rygo6 Posted May 16, 2016 Share Posted May 16, 2016 I have a curve, I want to split this curve into a multitude of seperate segments, that have no gaps. Ideally by specifying the number of points allowed in each segment. Essentially the 'Add' node with the 'Group of N Points' value specified, but that produces gaps between each new segment, I need it without gaps. How do I do this? Quote Link to comment Share on other sites More sharing options...
Ironic Posted May 16, 2016 Share Posted May 16, 2016 Use the resample sop. Quote Link to comment Share on other sites More sharing options...
f1480187 Posted May 16, 2016 Share Posted May 16, 2016 Group each n'th point, then use PolyCut in Cut mode. Gaps for visibility only. segmentate_curve.hipnc 1 Quote Link to comment Share on other sites More sharing options...
rygo6 Posted May 16, 2016 Author Share Posted May 16, 2016 Beautiful, thank you. Quote Link to comment Share on other sites More sharing options...
rygo6 Posted May 17, 2016 Author Share Posted May 17, 2016 (edited) I need more help now. I am now sweeping this curve. It produces separated meshes. But, I need each of those separate meshes to be in a separate group. How would you do that? They need to be in separate groups because I am ultimately trying to get these to load into Unity as separate meshes. Putting them in separate groups is how you do that. Edited May 17, 2016 by rygo6 Quote Link to comment Share on other sites More sharing options...
f1480187 Posted May 17, 2016 Share Posted May 17, 2016 Many ways. There is checkbox on Sweep to output groups. As general approach, Assemble node or Connectivity followed by Partition. Depends on use-case. assemble_segments.hipnc 1 Quote Link to comment Share on other sites More sharing options...
rygo6 Posted May 17, 2016 Author Share Posted May 17, 2016 Oh wow just create groups on sweep. Thank you, I had the gnarliest concoction going with a foreach loop.... 1 Quote Link to comment Share on other sites More sharing options...
rygo6 Posted May 23, 2016 Author Share Posted May 23, 2016 (edited) I have a new problem. There are now small gaps in between my sweeps due to the curve being separate. See this image: How would I fix that? I am thinking somehow I need to add one more vertex before and after each cut in the curve so that the sweep is aligned. Edited May 23, 2016 by rygo6 Quote Link to comment Share on other sites More sharing options...
anim Posted May 23, 2016 Share Posted May 23, 2016 Sweep SOP can use instancing attributes (like N, up, orient, pscale, ...) so you can create for example N and up on original curve using PolyFrame SOP then Sweep will use those for orienting cross-sections and since they would have the same values for split points, the cross-sections would align since you didn't post your file, here is modified F1's file: orient_multisegment_sweep.hipnc Quote Link to comment Share on other sites More sharing options...
rygo6 Posted May 23, 2016 Author Share Posted May 23, 2016 (edited) Thank you thats working. It introduced one problem though. On my sweep I had a curve attached to the reference slot of the sweep sop to control the up orientation of my sweep. Using your described technique seems to override this, it now ignores the reference curve for up orientation. Is there someway I can get that mixed into it? Edited May 23, 2016 by rygo6 Quote Link to comment Share on other sites More sharing options...
anim Posted May 23, 2016 Share Posted May 23, 2016 sure, you have full control over N and up attribs (or other), so you can create them as you wish, if you need help with that post your file Quote Link to comment Share on other sites More sharing options...
rygo6 Posted May 23, 2016 Author Share Posted May 23, 2016 Ok attached is my file. I am only trying to get the 'Sweep1' node working properly, I will copy the correct fixes to the other sweeps. By properly I mean, have the PolyFrame node to what it does do close the gaps between sweep sections, and also have the sweep oriented up towards the reference curve. I was trying to read more about the 'Attributes from Path' section of sweep but am not quite following it. On your example you put '* ^P ^N' I presume the ^N takes the info from the PolyFrame node with N in the tangent name. But I don't understand where P is coming from, nor what ^ signifies, nor what * signifies. So I could not decipher how to get the up normal of the reference curve mixed into that. Is there anywhere that describes these things in more detail? The info page on the sweep node doesn't have much info. Track2.hiplc Quote Link to comment Share on other sites More sharing options...
anim Posted May 23, 2016 Share Posted May 23, 2016 (edited) here is modified file with custom up attribute created from reference curve: Track2_fix.hiplc also ^N is there just to prevent swept geometry from inheriting N from backbone (the same as what ^P is for by default), as it is just meant for orienting cross-sections and not to actually affect the N attrib or anything what * ^P ^N actually means is: *(inherit all attributes from backbone) ^P(except for P) ^N(and except for N) more about it here: http://archive.sidefx.com/docs/houdini15.5/model/groups#manual Edited May 23, 2016 by anim Quote Link to comment Share on other sites More sharing options...
rygo6 Posted July 17, 2016 Author Share Posted July 17, 2016 Hello, if by chance you are still around. I have encountered another I didn't notice before. Using this setup the beginning and end of the track has a gap. It seems that the tangents on the point where the track closes are not in alignment. Is there a way to fix that? Quote Link to comment Share on other sites More sharing options...
