Hey Guys,
I finished this project a while back. I included it in my showreel just before the FMX. If you want to see breakdowns of the scene, it's in my showreel. I also show the diversity of the shader used. The Breakdown starts at 00:40. In the bottom video you can see the WIP too.
Everything but comp is Houdini. Mountain range is completely procedural. The Shader is procedural, snow amount is slope and height dependent mixed in with noise, you can determine the snow / rock bias too. The rocks under the snow is in the same shader and is controllable by reflection and displacement amount.
There are three smoke sims on the left, top and right of the shot. The top one is a clustered pyro sim. In the top sim I used the velocity field to advect some particles for the snow effect.
In the background the clouds are VEX Volume procedurally generated.
