Thein Win Posted May 20, 2016 Share Posted May 20, 2016 I cannot make all of them rotate to the same direction. Can anyone please help. Quote Link to comment Share on other sites More sharing options...
Thein Win Posted May 20, 2016 Author Share Posted May 20, 2016 i think i got it. Thanks! Quote Link to comment Share on other sites More sharing options...
MirrorSword Posted May 22, 2016 Share Posted May 22, 2016 You might already know this, but this page in the houdini docs has really good info about how point attributes can be used to affect the transforms of copied objects. You shouldn't have to use copy stamping to affect the scale or rotation of copies, you should just use these point attributes. Quote Link to comment Share on other sites More sharing options...
jingaa Posted May 31, 2016 Share Posted May 31, 2016 Maybe you can add point sop before copy and connect from template side (to right side)... change the keep normal to add normal and give there 1 instead of @N.x or you can use $TX , $TY , $TZ Quote Link to comment Share on other sites More sharing options...
