Yorkst Posted May 21, 2016 Share Posted May 21, 2016 I added several points of line to a group "roots". Before applying polywire node to line, I have 400 points in group. After applying - 0. Quote Link to comment Share on other sites More sharing options...
DennisSchmidt Posted May 21, 2016 Share Posted May 21, 2016 This happens due to the fact that you are creating a new geometry. To get your grouping back use the "Group Transfer" SOP and change the group name conflict to overwrite. Hope that helps. Dennis 1 Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted May 21, 2016 Share Posted May 21, 2016 You can also create an attribute with value "1" before using a polywire. Quote Link to comment Share on other sites More sharing options...
Yorkst Posted May 22, 2016 Author Share Posted May 22, 2016 Thanks! I initially used attrubutes to solved this, but I knew there should be solution with groups Quote Link to comment Share on other sites More sharing options...
