Point String Attribute to a FILE_NAME in a FILE SOP
Hi guys.
I have an array of points with an attribute @mesh_path and @map_path
@mesh_path = "/mnt/projects/model/mesh.001.proxy.OBJ"
and File SOP connected below
I can't read file if I use attribute in a FILE_SOP text Field.
`@mesh_path`
Is there any possibility to use string variable in FILE SOP text field to read the file?
Edited by Anatol
Thank you, Anim! I'm Using ForEach for an array of points to load a geometry to a scene. This really works )) Now I'll try to make some scatter on this ))
Edited by Anatol
I've got it. Looks like Instance SOP really doesn't needed for ForEach.
Watching attached scene, Dived inside Instance SOP
I still have a problem with a string attributes or stamping attributes in TextField. Same story but another attribute @map_path. I need to read attributes loaded from Attribfrommap SOP for each piece of geometry wich corresponds to certain point :(
Edited by Anatol
Problem Solved. Problem was in expression. point("../node", 0, '"attr", 0) doesnt support for string attributes. Instead of this I've used points() expression function.
I've incerted this expression in the FILE_SOP textfield >>>   `poins("../node", 0, "path_attr")`
Now I able to load the pieces I needed and load any attribute for corresponding piece of geoometry with Attribfrommap SOP.
I cant upload work project here, but I try to prepare and upload scene here a bit later.
Thank you :)
Edited by Anatol
  • Thanks 1
