Whats wrong with this expression?
So I have a switch node I want to direct based on what another switch node's channel is set to. AFAIK || is the "OR" nomenclature but going back to H13 I have not been able to get this to work. Basically if the first switch is set to 3, 5 or 6  set the second switch to 1.. if its not 3,5 or 6 flip it the other way.
This is the expression that I have, but it seems to result in in any value being true (1). What am I doing wrong? it doesn't error :)
if(ch("../switch_GLV/input")==3 || 5 || 6, 1,0)
if(ch("../switch_GLV/input") == 3 || ch("../switch_GLV/input") == 5 || ch("../switch_GLV/input") == 6, 1, 0)
It is unnecessary to wrap it if you need to return true if true and false if false. Unless you type it for testing puproses, you may simplify it to this:
Multi-line style using variable.
	float input = ch("../switch_GLV/input");
	return input == 3 || input == 5 || input == 6;
If you switch to Python, you may use:
ch("../switch_GLV/input") in (3, 5, 6)
