Read only expression given for write only parameter
I want to use a snippet vop to change some binded attributes, but it doesn't allow me. The error message is very ambiguous.
So I am binding some HDA parameters to certain names:
  1. myattribute -> result
then inside the snippet vop, I do:
  1. @result = 1;
It throws that error. Is this normal?
I set Bindings to Export to * so not sure what else I can do.
