Using a SOP Solver to delete points that will enter a group
vfxhound
Hi guys, a friend was asking if he had some moving points and for example there's a group by bounding box, so some points enter the group for a few frames. Is there a way to delete those points from the entire sequence?
I was wondering the same thing myself, so I gave it a go using a SOP Solver. Check out the example file.
delete_red.hipnc
so they already should be deleted in the first frame? based on them entering the bounding box later?
In your file, enable delete_red_points, the result at OUT_WITH_SOLVER is what you want to achieve?
if yeah, then point wrangle with
if(@P.y <= 1.3) {removepoint(0, @ptnum)}
1.3 is half the height of your bounding volume
use expression to make it procedural
