scooter1507 Posted July 26, 2016 Share Posted July 26, 2016 hi, i was wondering how to select faces of any geometry. using groups and packed geo. Quote Link to comment Share on other sites More sharing options...
3dome Posted July 26, 2016 Share Posted July 26, 2016 packed geo is just a point. you cant select faces on packed objects. unpack first, then select whatever you need Quote Link to comment Share on other sites More sharing options...
old school Posted July 28, 2016 Share Posted July 28, 2016 Depends on what you want to do. If you need to work with the faces in SOPs, then yes Unpack SOP is what you need to do. Only unpack what you need. There is "one way" to select faces on deferred primitive types (packed prims, alembic archives) and that is to use the Style Sheet Data Tree interface. You can use the style target option Selection from Viewport to select faces buried deep in any archive to do shader/material and Mantra property overrides. Viewport selections can be any group or @attribute group type selection. All selection options are available within the Style Sheet selection target tool. Quote Link to comment Share on other sites More sharing options...
