meeotch Posted August 12, 2016 Share Posted August 12, 2016 Is it possible to access an arbitrary piece of geo (i.e., not the one being shaded) from a shader? I know that you can read data from pointclouds on disk. I also read somewhere that the "op:" syntax doesn't work for shaders (although it does work for referencing COPs from a shader, yes?). Presumably, you'd have to alert houdini somehow to the fact that there was non-rendered geo that needed to be pushed to the ifd. The context is that I'm trying to write a shader that does coloring based on distance from a set of guide curves. The color transitions need to be sharp, not blurry, therefore baking the colors into the shaded surface's points in SOPs isn't an option, unless I dice it up into a zillion polys. (I suppose a fallback plan would be cooking the color info down into a very large texture. But all of this is animated, so I'd prefer not to render a few hundred frames of textures.) I can confirm that using the xyzdistance VOP from within the shader doesn't seem to work - neither with op: syntax, nor reading the curves from a file on disk. Quote Link to comment Share on other sites More sharing options...
dchow1992 Posted August 12, 2016 Share Posted August 12, 2016 check to see if you forgot to transform P to object/world space before xyzdist Quote Link to comment Share on other sites More sharing options...
meeotch Posted August 12, 2016 Author Share Posted August 12, 2016 D'oh! Dude - nice one. You're like a psychic for boneheaded mistakes. Reading the curve geo from a file seems to work, with that fix. op: syntax still doesn't work, which is not entirely surprising. Anyone know if that's is something that's been implemented, and maybe it's another "PEBKAC" issue? Quote Link to comment Share on other sites More sharing options...
