Call pcopen() on groups of points dynamically?
Hey everyone! First time posting :)
I have a variable number of groups of points, and I want each point to find its nearest neighbor in every group that is not its own. I know pcopen() takes in either an Opinput or a filename, so I was wondering if there is a way to somehow dynamically set inputs to take in groups or if there is a way to export groups of points to a file without manually having to delete non-selected on each group and exporting them individually with the file sop.
If groups don't overlap, convert groups to name attribute using Name node and then use nearpoint function:
// Point wrangle.
i@near = nearpoint(0, "!" + s@pt_group_name, @P);
// Test.
int prim = addprim(0, "polyline");
addvertex(0, prim, @ptnum);
addvertex(0, prim, @near);
Effect is pretty nice on clustered geo.
exclude_itself_group.hipnc
Here is pcfind signature accepting a group. I think it is an equivalent of the nearpoints function, which also return an array.
int [] pcfind(int inputnum, string ptgroup, string Pchannel, vector P, float radius, int maxpoints);
If you really meant pure VEX solution, without converting stuff, use something like this:
// Point wrangle.
string groups[] = detailintrinsic(0, "pointgroups");
foreach (string group; groups)
    if (inpointgroup(0, group, @ptnum))
        i@near = pcfind(0, "!" + group, "P", @P, 1e10, 1)[0];
        // Test.
        // Exit loop.
        break;
It will act similar. Just a bit more code.
exclude_itself_group_pcloud.hipnc
Edited by f1480187
