Fyre Posted August 25, 2016 Share Posted August 25, 2016 Done some searching for an answer but can't find one - sure the answer is simple: impact analysis on packed rbd object (using bullet solver) returns nothing. Attribs are only exported when the object isn't packed. Is it possible to get impact analysis on packed rbds? Quote Link to comment Share on other sites More sharing options...
sekow Posted August 25, 2016 Share Posted August 25, 2016 bullet has it own impact data and can be imported via dop import records sop Quote Link to comment Share on other sites More sharing options...
Fyre Posted August 26, 2016 Author Share Posted August 26, 2016 (edited) Thanks for your respons sekow, i'm looking at the dop import records sop and im not entirley sure what i should be importing for the impact data? EDIT: Managed to import the Impact point data, however there is no impacttime attribute, only time and they are all set to the current time, not their collision time. Also the normals all say 0 1 0? Edited August 26, 2016 by Fyre Quote Link to comment Share on other sites More sharing options...
