acess previous point attribute in wrangle
vijayakumar
Hi guys,
need help in vex. I tried creating an attribute in for loop and access the previous point value . But i couldn't access the created value. Here is the code. in this i am creating an integer a and storing the value. i am trying to use point(geoself) and access the previous point attribute but it defaults to zero. help me out with this.. thanks..
int @a=1;
int @test[];
int @inst;
if(@ptnum==0)
@test[0]=1;
for(int i=0;i<=@ptnum;i++)
@a=@a+i;
if(@ptnum>0)
@inst=point(geoself(),'a',i-1);   //cannot access the previous value
@test=point(geoself(),'a',i-1);
You need to do such things in different wrangles, because geometry wrangles are writing attribute values at the very end of execution.
// First Point wrangle.
i@a = (@ptnum+1) * @ptnum / 2;
// Second Point wrangle.
i@a_prev = point(0, "a", @ptnum-1);
Or use Detail wrangle, use explicit functions for setting attributes and keep track of previous values manually:
// Detail wrangle.
int a = 0;
int a_prev = 0;
addpointattrib(0, "a", a);
addpointattrib(0, "a_prev", a_prev);
for (int i = 0; i < @numpt; i++)
    a_prev = a;
    a = (i+1) * i / 2;
    setpointattrib(0, "a", i, a);
    setpointattrib(0, "a_prev", i, a_prev);
The drawback of using Detail wrangle is that you need to use explicit functions, which is a bit more lines of code. It is also single-threaded, but still very fast in most cases.
previous_point_value.hipnc
Edited by f1480187
