Transfer attribute from SOPs to POPs
ITdreamer
Hello
I have a cube and a sphere. Sphere is the source for the particles. I also scattered lots of points on the cube.
I want particles to go from sphere to points scattered on the cube, but I can't figure out how to import scattered points position as a target attribute for the particles.
And then use @v = @target - @P
Any help please?
Oh! I found it.
The answer is by using SOP Solver.
By the way, POP Solver has got 3 inputs (Source, Pre-solve, Source (post-solve)).
I've created sop solver and connected it to the last input under the source node. I also tried to connect it to the second input (pre-solve) of the POP solver. The result was the same.
I want to understand when it makes difference to use pre-solve input and source input (post-solve)?
  • 1 month later...
