InlineCPP
MrScienceOfficer
import inlinecpp
inlinecpp.extendClass(hou.Geometry, "geo_merge_HOM_ext", "", ["""
void mergePrimGroup(GU_Detail* gdp, const GU_Detail* src, const char* prim_grp)
    gdp->merge(*src, src->findPrimitiveGroup(prim_grp));
"AttributeError: function ?mergePrimGroupy...yadadada not found"
This error only occurs when "src" is const, or gdp isn't const.  Basically if the const-ness of the GU_Detail args are mismatched the function "can't be found".  Does anyone know anything about this?
Thanks
1 hour ago, graham said:
Are you on Windows?
Sorry, yes... of course, sigh...
Do things work better if you put the prim_group arg in between the detail args?
Truly a noble effort but alas no.
I suppose the only thing left to do is send in a bug report just in case, and just take the geometry as a SOP_Node instead.
Thanks Graham.
