VEX - converting ints and floats to strings
SteveNi
Hi
So basically I have a certain float value, lets say 3.68, and I want to get the digits before the comma (there are no functions that rounds to the lowest integer), so that I can later use that in some math operations.
I know I can use split() to split to the point, and sprintf() to convert to string, but I cant get this last function to work, for example if I wrote
float _x = sprintf("%g",3.68);
But this gives me an error...
Anyone knows how to convert to string and back to the original variable type?
Thanks
I think  MrScienceOfficer give you what you are looking for.
BTW, to convert float to string and string to float, etc...:
itoa: https://www.sidefx.com/docs/houdini15.5/vex/functions/itoa
atoi: https://www.sidefx.com/docs/houdini15.5/vex/functions/atoi
atof: https://www.sidefx.com/docs/houdini15.5/vex/functions/atof
Awesome!!
I didnt know those functions...
Also I was searching for a function to round to the larger integer but I managed to do that by doing this thing on the number I need to round:
Example with 2.81:               2.81 + (1- (2.81%1))
Thanks a lot :)
