How to use extra files in HDAs in python
sanostol
hello,
in the script tab of a otl the is a way to ad custom scripts, but how can I use them for a button in that hda, or even better in the python module. until now i used always the python module or imported addition code with import, but I want to package some hdas together not using external imports and I don't want to have double code on several assets, as some functions are used by all of them
thanks
Martin
  • 2 weeks later...
import toolutils
bar = toolutils.createModuleFromSection
https://www.sidefx.com/docs/houdini/hom/hou/HDAModule
If you want package bunch of operators together, nothing stops you from defining all your common Python code in one PythonModule of one operator, and then reference this module using opdef: syntax. in other operators.
Edited by Stalkerx777
