Juzwa Posted October 28, 2016 Share Posted October 28, 2016 Hi, So I noticed they changed the group sop again. Im pretty sure it used to be able to select faces, now it selects the whole object. So what I use Bounding Object (points only), and then when I convert the selected point group to primitives, the whole object is grouped. I think this used to work differently. Like a primitive is a whole object (I always though that a primitive is like a poly). So how can I select faces? selectAndConvert.hiplc Quote Link to comment Share on other sites More sharing options...
Juzwa Posted October 28, 2016 Author Share Posted October 28, 2016 Ok learning every day. So when I turned on primitive numbers to display in my viewport I noticed that every prim was 0. So this means that in houdini a mesh is not made from primitives and this is not the same as polygon mesh.... So confusing Quote Link to comment Share on other sites More sharing options...
