Transfer primitive attribute to generated centroid point?
fiverob
Hey everyone,
So, I'm attempting to recreate this packed objects / dart throwing technique from Simon Holmedal.
I feel I'm close, but I'm struggling with a n00b problem and was hoping someone could take a look and help me out.
I have an attribute on the primitives that I want to drive the scale of the copied spheres. I've done an attribute wrangle on the primitives to create new points at the center of each which I plan to use as the locations for the copied spheres. I just can't seem to work out how to transfer the attribute AND delete the primitives. I'm not having any luck with the attribute transfer node.
Any ideas?
Thanks legends.
DartThrowingAttempt.hip
you can use setattrib to set point attributes
ex:
int newpt = addpoint(0, @P);
setattrib(0, "point", "pscale", newpt, 0, @area);
removeprim(0, @primnum, 1);
make sure you have pscale on your points
edit*couldn't resist trying to make something
kinda slow though, i'm sure there's a better way
sphere_packing_005.hip
Edited by dchow1992
