Is it possible to cache Multiple Dop I/O with takes ?
ValentinD
Hello everyone,
I used to cache multiple alembic using the technique described here : http://nicholaspfeiffer.com/blog/2016/1/16/houdini-tip-of-the-day-render-multiple-alembic-rops-at-one-time (Long story short : rop network > multiple fetch > a merge > click render >  caches every fetch. That's cool !). I thought that it would work the same way if I use this technique to render multiple Dop I/O node.
For the first time I want to use the take system to cache multiple sim over the night (changing resolution and parameters). So in an obj node I dropped 2 Dop I/O, set their "Render With Take" parameter on each one, then dropped a Rop Network, two "Fetch" nodes and set their path to the dop I/O "render", dropped a merge, and hit "render".
The result expected would be to have the different takes cached but instead I had the Main take cached, two times...
What do I do wrong ? Thanks for the help, if a scene is needed I will do a simple version of it :)
Have a great day/night !
Hello Shinjipierre,
Thanks for pointing out the wedge node, I did not knew it.
I have tried again and it seems that the problem is coming from the take system... I will do another post to explain it...
Thanks anyway !
EDIT : I have retried the ropnet with fetch method, it worked, it seems that the first time I had done something wrong.
EDIT 2 : Here is the other post :
Edited by ValentinD
