catchyid Posted November 6, 2016 Share Posted November 6, 2016 (edited) Hi, The documentation says that I could create image plan per light source, e.g. I can output the direct diffuse contribution per light source. To do so, I enabled: Mantra Node--> Extra Image Planes --> Direct Lighting (Per Component). However, when I check my rendering folder, I see ONE diffuse image plan for all lights in the scene and Not every light source. https://www.sidefx.com/docs/houdini15.5/render/noise Quote For complex scenes with many lights, it can be useful to export the “Direct Reflect” layer using the “Per Light” option. This will allow you isolate the specific lights that are causing noise in your scene, allowing you to increase sampling only on the offending light sources. Is there an automatic way to output the rendering contribution per light source as mentioned in the documentation above? UPDATE: I found this link and in 2012 having contribution per light source was not that easy...I am not sure if this has changed in 2016 I don't think having light contribution per light source is that important, it's just mentioned a lot in Houdini documentation to troubleshoot noise and I thought it would be possible to have it out of the box! Edited November 6, 2016 by catchyid Quote Link to comment Share on other sites More sharing options...
rbowden Posted November 6, 2016 Share Posted November 6, 2016 It definitely works. Make sure you are changing your per light exports to export variable for each light and change your export components to just diffuse (since that is all you want) Quote Link to comment Share on other sites More sharing options...
catchyid Posted November 6, 2016 Author Share Posted November 6, 2016 Thanks Ryan Could you plz tell me which panel or which node that has these export variables? Quote Link to comment Share on other sites More sharing options...
rbowden Posted November 6, 2016 Share Posted November 6, 2016 (edited) For some reason I can't upload an image or post an attachment for you so, the best I can do is try and tell you: Under Extra Image planes tab in the Mantra ROP, change export components to be just diffuse (if you just want diffuse). Lower down from that, add one extra image plane and under the vex variable drop down, change it to direct lighting (per component). Lower down from that, you will see light exports. Change that to: Export Variable for each light. Edited November 6, 2016 by rbowden 2 Quote Link to comment Share on other sites More sharing options...
catchyid Posted November 8, 2016 Author Share Posted November 8, 2016 Hi Ryan, Thaaaaaanks for the help, and it does work as you mentioned Somehow I missed it in the documentation. Quote Link to comment Share on other sites More sharing options...
