JohnnyBGoode Posted May 12, 2005 Share Posted May 12, 2005 Hi. My current scene makes use of quite a bit of camera mapping. I want to deform some of the objects, however, because the texture is projected from a camera onto the geometry, any deformations dont effect the texture. How do I do this? I assume I have to bake out or lock the texture in some way. Im not quite sure how to do this with a camera projection - and if i do, how do I then reproject it correctly? Any advice would be much appreciated ive read in Maya that you can create a Texture reference object to do this....anything similar in Houdini? J Quote Link to comment Share on other sites More sharing options...
JohnnyBGoode Posted May 12, 2005 Author Share Posted May 12, 2005 ok managed to answer my own question. but ill post for benefit of others simply created a new geo - inside that an object merge and referenced my projected object. Now I can deform with the textures staying locked. Any way I could do alternative methods/improvements? J Quote Link to comment Share on other sites More sharing options...
sibarrick Posted May 12, 2005 Share Posted May 12, 2005 (edited) How about just copying the uv's back onto your object from one written out to disk in it's undeformed state. The point sop, vertex sop or attribcopy sop will do the copying depending on the type of uv's Actually why aren't you just creating the uv's higher up the chain before the deformations? Edited May 12, 2005 by sibarrick Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 12, 2005 Share Posted May 12, 2005 Hey Johnny, You're projecting the texture from a light, so to fix the texture you have to use rest positions. Add a RestPosition SOP before the deformations and feed both inputs with the same data. Then in your shader you'll need to add a vector parameter called "rest", whose value can default to P. Now, wherever you currently use "P" to do the texture lookup, you'll use "rest" instead. But since rest is now defined in object space, you actually need to use "ow_space(rest)" -- in VOP-speak, this would be an "Object to World" transform using the SpaceChange VOP. Hope that makes sense, Cheers! Quote Link to comment Share on other sites More sharing options...
