How to make a force inactive after the mask field is gone?
violalyu
Hi houdini friends,
Is there a way to deactivate the force when it's not in the mask field? Right now I'm doing a scene where leaves rise when a car pass them. I tried to use the mask field to mask out the area that should be affected when the car come, but as the car goes by those affected leaves seem to be still affected by the wind force, but they should fall down eventually. Does anyone know the solution to this? Thank you so much!!!
