bluciensky Posted November 19, 2016 Share Posted November 19, 2016 I have a float attribute called "test" that retuns 0-1 If I want to use that attribute value on the parameter on my wrangle, how do I write the expression? I tried point("/obj/test", @ptnum, "test", 0) This expression doesn't error out, but returns the value of point number '0'. If I write point("/obj/test", 3, "test", 0) then it returns the "test" value of point number 3, but it just that @ptnum doesn't work. What did I miss? Quote Link to comment Share on other sites More sharing options...
anim Posted November 19, 2016 Share Posted November 19, 2016 parameters on wrangle aren't evaluated per point or element so instead of point() expression on parameter, you need to use point() VEX function in your wrangle code either as point(1, "test", @ptnum) if the geo is connected to second input for example or point("op:/obj/testobj/testsop", "test", @ptnum) to reach geometry from any unconnected sop node (for both examples the sampled geo may possibly have the same pointcount so that @ptnum finds corresponding points, but it's up to you how you want to use it) Quote Link to comment Share on other sites More sharing options...
