Rygantic Posted November 22, 2016 Share Posted November 22, 2016 Hi guys, Please excuse my complete noobness here. I'm following one of the Entagma tutorials where they create a fractal type shape with the for loop node, and I've been trying to recreate the expression they used in an Attribvop. I've set the pscale with a bind export node but I can't seem to figure out how to use this to scale each iteration of the for loop. I've attached my file - any help would be most welcome! Thanks, Rygantic Fractal_For_Loop_003.hipnc Quote Link to comment Share on other sites More sharing options...
vtrvtr Posted November 23, 2016 Share Posted November 23, 2016 I don't remember exactly what they are doing in the tutorial, but is this what you want? I didn't change anything besides the wiring 1 Quote Link to comment Share on other sites More sharing options...
Rygantic Posted November 23, 2016 Author Share Posted November 23, 2016 Yes that's the one, I've rewired it as per your image and its working but only if I turn on 'Transform Using Template Point Attributes'. In the example they had this switched off to keep it uniform. I'd like to keep it off in this set up too, any ideas as to why its not working? I've also noticed some of the nodes are connected with dashed lines, what does this mean? Thanks for you help! Ryan Quote Link to comment Share on other sites More sharing options...
