catchyid Posted November 27, 2016 Share Posted November 27, 2016 Hi, I've used the shelf tool "smoke cluster" to create partitioned container. Initially, the simulation worked as excepted, however when I changed the smoke source to a sphere, the solver did not produce any smoke!? I am not sure why the "default" smoke source works while the new one does not... Thanks, smoke_clustering_question.hiplc Quote Link to comment Share on other sites More sharing options...
catchyid Posted November 28, 2016 Author Share Posted November 28, 2016 I found the problem! it was : dop network --> source volume --> instancing --> instancing = On. The correct setting is Off. I am not sure I understand it correctly, but it seems like if I have one smoke source (i.e. not an instanced copies), then I should that parameter to Off. Quote Link to comment Share on other sites More sharing options...
