Export particles sim to PFX
Anti-Distinctlyminty
Hi all,
I've been trying and failing for two days to get the results of a particle sim into another package. The particle cache format is documented here:
http://forums.newtek.com/showthread.php?129146-fcache-specification&p=1255059&viewfull=1#post1255059
The format is roughly:
Header Data
Particle Header Data
	Particle Position at Frame 1
	Particle Position at Frame 2
	Particle Position at Frame n
As you can see the format requires data for each particle to be in sequence, which is an issue, as at each frame I can iterate over the points, but I cannot possibly know how many frames each particle lives for at some random frame.
Does anyone have any ideas on how to do this? I've tried using a shuffle CHOP to rearrange the data, but it's just too slow to be useful.
