s---70 Posted December 9, 2016 Share Posted December 9, 2016 (edited) I am getting an almost perfect voronoi fractured mesh, but at some points the edges on the outside just dont match up. I need a perect outside shell for further processing, so can this somehow be avoided? I tried with voronoi fracture points and with a scatter on an isooffset, both methods result in this problem. I could somehow fix this in VEX probably but I'd rather get this right in the first place... voronoi problem.hiplc Edited December 9, 2016 by s---70 Quote Link to comment Share on other sites More sharing options...
stevegh Posted December 9, 2016 Share Posted December 9, 2016 Have you tried adjusting the 3D tolerance in the fracture sop? Quote Link to comment Share on other sites More sharing options...
f1480187 Posted December 9, 2016 Share Posted December 9, 2016 Triangulate non-planar faces using Divide node. 3 Quote Link to comment Share on other sites More sharing options...
s---70 Posted December 10, 2016 Author Share Posted December 10, 2016 Quote Triangulate non-planar faces using Divide node. thx, that helped but didn't fix it in all occurances. Quote Have you tried adjusting the 3D tolerance in the fracture sop? what do you mean by 3d tolerance? My approach is now to find nearby points and set them to the same position before applying a clean to remove degenerate prims, but its always a bit of a pain in the ass when you have to find a threshold that works and its not really procedural. Quote Link to comment Share on other sites More sharing options...
s---70 Posted December 10, 2016 Author Share Posted December 10, 2016 (edited) so if anyone is interested, this is how I fixed it: attribute wrangle running over detail with this code, ch("epsilon") being a float parameter to control the distance in which near points are searched int npt = npoints(0); int moved[]; resize(moved, npt); for(int i=0; i<npt; i++) { if(moved[i]) continue; vector pos = point(0, "P", i); int pcpts[] = pcfind(0, "P", pos, ch("epsilon"), 100); vector center = 0; int count = 0; int tomove[]; push(tomove, pcpts); foreach(int pt; pcpts) { if(moved[pt]) { removevalue(tomove, pt); continue; } vector posi = point(0, "P", pt); center += posi; count ++; } foreach(int pt; tomove) { moved[pt] = 1; setpointattrib(0, "P", pt, center/count); } } after that a clean with default settings edit: changed the clean afterwards to a simple delete -> delete degenerate primitives and set the tolerance smaller than default, bcause default clean removed some small polygpns. Edited December 10, 2016 by s---70 2 Quote Link to comment Share on other sites More sharing options...
