vineet Posted January 9, 2017 Share Posted January 9, 2017 I want to transfer my multiple packed geo transformation and rotation on a static geo with multiple packed primitives just like i done on my attached file single point(green) net box rotRnD.hipnc Quote Link to comment Share on other sites More sharing options...
f1480187 Posted January 9, 2017 Share Posted January 9, 2017 Here is seven different methods: xform_pieces.hipnc In your particular case you need to replace Transform node with Primitive SOP and do similar setup using $PR/@primnum as a point number. 1 Quote Link to comment Share on other sites More sharing options...
vineet Posted January 10, 2017 Author Share Posted January 10, 2017 18 hours ago, f1480187 said: Here is seven different methods: xform_pieces.hipnc In your particular case you need to replace Transform node with Primitive SOP and do similar setup using $PR/@primnum as a point number. Thank u very much.... Quote Link to comment Share on other sites More sharing options...
