point sop to wrangle sop translation
I'm new trying to learn the basics of using the Wrangle sop. As a test I used an expression from the expression cook book in the Houdini docs. So there is a line and a point sop. In the position fields of the point sop the expressions are:
X: cos(@ptnum *5)
Y:@ptnum/400
Z: sin(@ptnum *5)
this makes a spiral from the line.
I want to do the same thing with the attribwrangle. So naively i tried:
@P.x = cos(@ptnum *5);
@P.y = @ptnum/400;
@P.z = sin(@ptnum *5);
What this did to the line was interesting. but was not the same as what the point sop did.
I think if some one could explain how this is done it would help me a bit.
thanks very much,
b
Edited by bonassus
Expressions are always floats. @ptnum is an integer attribute in VEX, even if you omit type (which will be defaulted to f@foo for some random attributes). You should use floats to avoid integer arithmetic. Here is plain and stupid example:
3 / 2 == 1
3.0 / 2.0 == 1.5
3.0 / 2 == 1.5
3 / 2.0 == 1.5
(float) 3 / 2 == 1.5
3 / (float) 2 == 1.5
int_var / int_var == integer_result
int_var / float_var == float_result
float_var / int_var == float_result
Edited by f1480187
1. You need to convert operands, not result.
cos(3 / 2) == cos(1)
cos(3.0 / 2) == cos(1.5)
2. In that case, it's more like a frequency problem (spiral swirls too much). Expression's sin() expect degrees, VEX's sin() working with radians. You need to convert expression's example to radians, since it was set up to output big values.
cos(radians(3.0 / 2))
point_to_wrangle.hipnc
Edited by f1480187
  • Like 2
