brucelay Posted June 5, 2005 Share Posted June 5, 2005 Hi! I am a CG student learning renderman and Houdini by myself. I have 2 objects in geo level. One of the objects is atttached by a "shader" node. The other object is attached by a "Rman shader" node . But eventually only the "rman shader" node 's shader can be rendered after I merge 2 objects together. Does anyone know why? How can I have both "rman shader" and "shader" node to be rendered at the same time? thanks for your attention! Quote Link to comment Share on other sites More sharing options...
