export velocity into vdb from pyro sim
nicoladanese
Hey All!
I'm trying to write out some vdb caches from a pyro sim. As long as I plug the DOP Import into a VDB convert and then into a file everything looks great and I get my density for render. Problem is, now I want to write out velocities of the volume so I can later import it in a fresh scene to advect some particles. I can't find a way to enable the DOP import to get the velocity, so I'm plugging the DOP I/O which has all the field I need. BUT the cache is getting much much heavier in terms of disk space. I am writing out 4 scalar fields (density vel.x vel.y and vel.z) so I'm expecting the cache to be roughly 4 times bigger, but in my case frame 10 was around 2 Mb and now is 240 Mb
any one with some ideas? Thanks in advance!
here some screens of how I'm setting this
You can have velocity where you have no density.
DOP networks are using Houdini volumes so all fields should have the same dimensions and "weight", I mean, filesize.
Since you convert to VDB you are scrapping out useless voxels. If you have the situation described above, each VDB cached field would have a different filesize, well, at least for density and vel.
vel.x, vel.y and vel.z should be have the same file size since they are all part of the same original field.
To import a field from a DOP network, use DOPImportField rather than a DOPImport.
if you want to double check which voxels will be stored:
after your VDB conversion, add a blastSOP and keep only one of your field then lay down a VDB Visualize Tree where you change the Active Voxels dropdown to Points.
Depending on which field you keep in your blast SOP you might see more or less points.
More points = more voxels = more Mb to store.
Hi Anthony, thanks for your reply!
you were right, the voxels for vel are basically filling up the bounding box of the volume in a few frames (I guess the reasons are collisions with geos) , while the density is very limited (I've attached 2 images for comparison)
Now I'm looking for a reasonable way of getting the velocity info without filling up the disks! I guess I can VDBresample vel field before writing it out to maybe a 10 times lower resolution field grid so I get the velocities I need , although I'm not getting the fine details...
