anthonymcgrath Posted January 18, 2017 Share Posted January 18, 2017 hey all another crowd question - is it possible to make the crowd drop the weapons they are carrying when they collide with my object and turn to ragdolls? It only seems to be stuck in the characters hand and it would be awesome to put layers like weapons and helmets on them and have all that fall off when they are hit with my object? right now my agent has an agent layer in that is pointing to the hammer mesh i built (simple shape built in another sop network) - its constrained to the hand nicely but how would i get those to disconnect when the character turns to ragdoll? Would it be another trigger setup? Quote Link to comment Share on other sites More sharing options...
cwhite Posted January 18, 2017 Share Posted January 18, 2017 You would need: 1) A shape in your agent's collision layer that is bound to the prop's joint. Then, the Bullet solver will update that joint's transform based on the results of the RBD sim, causing the hammer in the agent's display layer to be transformed. 2) No constraints between the prop's RBD object and any other of the agent's RBD objects. You can of course edit the constraint network manually, but you ideally shouldn't set up a joint limit for the prop joint in the Agent Configure Joints SOP, and should turn off the Pin Shapes With No Rotation Limits option on the Agent Constraint Network SOP 1 Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted January 18, 2017 Author Share Posted January 18, 2017 @cwhite ok thanks! I will take a look. I didn't know I could add a shape in the collision layer for the hammer model they carry I'll see if I can figure that out. My prop doesn't have any bone in there. I'm a bit puzzled there how to get one in but I'm thinking it might be similar to how the fbx comes in with bone nodes.. might just need one of those in the prop network I have setup? Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted February 27, 2017 Author Share Posted February 27, 2017 @cwhite hi i couldn't for the life of me suss this out. I've attached a scene because its just confused seven bells out of me now actually i was trying to go one further and do detaching limbs which i managed to get working in this scene with a prim wrangle in a sop solver in the sim network... but i couldn't get the skin to separate - i was told i need to use an agent layer but its the same problem - i've no idea how to use this layer properly and the docs aren't very helpful at all from what i can understand of them :/ can anyone take a look please? ta ant ragdoll_with_tearing_limbs_test.zip Quote Link to comment Share on other sites More sharing options...
cwhite Posted March 2, 2017 Share Posted March 2, 2017 If you're detaching limbs and the agent has deforming geometry (e.g. skin), you need to switch the agent to a layer which has different geometry that won't stretch out as the joints separate. This would involve slicing the geometry around the detachment point and adjusting the capture weights near the boundary, as well as possibly filling in the hollow interior. This of course means that you'd likely want to have a few predefined detachment points, unless you try to procedurally slice the skin geometry on the fly. 1 Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted March 2, 2017 Author Share Posted March 2, 2017 @cwhite awesome I have no prob sorting that bit out but my problem is how to setup that agent layer to start with and also how to get the mesh to switch.. eg is it done in the solver sop in dops or somewhere else? I've only used an agent layer to put an object in the hands of a character like a hammer or sword I didn't know it can be used to do more like entire character switch. I've watched all sesi vids and a few others and nobody online is explaining how to setup that kind of system beyond "here's some dudes walking with hammers" :-/ Quote Link to comment Share on other sites More sharing options...
cwhite Posted March 2, 2017 Share Posted March 2, 2017 Yeah, the agent layer SOP can be used to add deforming shapes to a layer - just make sure to point it at the rest geometry (i.e. the input geometry to the Deform SOP). I think the H15 crowds masterclass had some examples of this. To switch an agent's display layer, you can use SOPs like the Agent Edit SOP, or change it in VEX via the setagentcurrentlayer() VEX function. Quote Link to comment Share on other sites More sharing options...
