HDA creation - parameters relative reference problem
Hi guys,
I am trying to create a simple hda which generates simple room with windows,door,etc.
After I create the asset from the subnetwork,everything is working fine (pic 1).
But if I want to access another instance I am losing the relative reference for the parameters (pic 2).
Someone might know what is the problem?
Tks.
you should set these expressions as the default values;
In the "Type Properties" window of the HDA, go to the parameters tab,
Select the first parameter you want to edit, go to the "Channels" sub tab on the right.
Then copy paste your expression into the left box(es) of that sub tab. (if it is a vector attribute from top to bottom they will be x, y z)
If you then apply/accept the changes to your HDA the expressions should be kept in every new instance.
