JDee Posted January 31, 2017 Share Posted January 31, 2017 Hi What I need is to find connected neighbors of every point of specific group. I guess that I need one loop inside of other loop in VOP, is it right way at all? so the firs one is for all the points I have in the group and then second one for all the neighbors for them? I feel like it's not so easy, with my knowledge of VEX. Is there more simple way, and how to specify group point numbers properly from outside VOP, so I don't need to set them manually in VOP every time ? Much appreciated any help. NFG.hipnc Quote Link to comment Share on other sites More sharing options...
iamyog Posted January 31, 2017 Share Posted January 31, 2017 a VEX solution int ls [] = array(); if (inpointgroup(0, "in", @ptnum)) { ls = neighbours(0, @ptnum); for (int i=0; i<len(ls); i++) { setpointgroup(0, "neighbours", ls[i], 1); setpointattrib(0, "Cd", ls[i], {1,0,0}); } } 1 Quote Link to comment Share on other sites More sharing options...
JDee Posted January 31, 2017 Author Share Posted January 31, 2017 45 minutes ago, iamyog said: a VEX solution It works perfectly thank you! Also found simplest solution for me with Group by edge depth, set it in 2 klicks, so it's actually grows your selection... yeah It's houdini. Quote Link to comment Share on other sites More sharing options...
