Set angle between poly
Sonofabeat
Hello folks.
I need to manually set the angle between 2 polygon, i now how to calculate the angle but i'm stuck on how to set it to a different value, i think that i have move the vertex opposite to the adiacent edge but i don't now how to find the correct coordinate.
Thank
Maybe this helps. its written for adding 45 degrees to the up normal, but the code could maybe also be used or converted to work for your goal.
v@up;
float angle = radians(45);
float cs = cos(angle);
float sn = sin(angle);
@up.x = v@at.x * cs - v@at.z * sn;
@up.z = v@at.x * sn + v@at.z * cs;
