varying @vel from @vel to 0 across a velocity volume?
nigelgardiner
Hi There
I have a velocity volume created using the normals of  a circle so that @vel is toward the centre from all points and @v.y = 0.
What I want to do is have @vel vary from it's max value at the circumference of the volume to zero at the centre.
I have the corresponding density volume with a filled interior which gives me a values of 0 at surface and 1 at the centre so how would i multiply @vel by (1 - fog density value)?
Any advice much appreciated, hip attached.
thanks
Nigel.
radial velocity volume.hiplc
