FrameChange EventCallback using HDK
If you really need to run c++ callback you can try this:
#include <HOM/HOM_Module>
HOM_Module &hom = HOM();
HOM_playber &playbar = hom.playbar();
playbar.addEventCallback(...);
P.S. Should work in theory, haven't tested it.
Edited by Stalkerx777
On 17/02/2017 at 11:24 AM, MrScienceOfficer said:
I've never seen anything.  If you need to call into C++ on time change events outside of a node, it's probably best to just create a python wrapper into your plug in.
Hello @MrScienceOfficer,
Can you please explain in detail, how to create such wrapper ?
Couldn't find similar thing in HDK Samples.
The sample for python wrappers is in the HOM folder.
../toolkit/samples/HOM/ObjNode_setSelectable.C
It's very well commented and should walk you through the process.
Any type prefixed with "PY_Py" is (in most cases) a wrapper to the CPython API.  So if you need to look up documentation you need to remove the "PY_" and look up the type here https://docs.python.org/2/c-api/
