prt exporter to 3ds max
Juzwa
Hi,
So I found this
https://github.com/FictionIO/PRTRop
Is that working for .prt for Krakatoa?
I know its a weird question. I should try that myself. However Im so busy that I dont have time to even try. Thats why I ask. I dont know if its worth spending time to get it to work. Its kind of old stuff (H12)
Or maybe you know any working 'tool' to export to .prt and read it in Krakatoa prt Loader?
Edited by Juzwa
I have used this plugin https://www.flipswitchingmonkey.com/houdini-prt-rop/
put it in your houdiniinstalldirectory/houdini/dso and it will show up in your /out level
make sure to export any attributes you want to use in magma flow, with correct names ( I think by default it renames v to velocity)
I have loaded it with prt loader in Max with this.
It works well as long as you're on top of the extended attribute naming conventions (as mentioned above) and was recently recompiled for 15.5.77. It's vital that you use the exact same version number of Houdini that was used to compile the version of PRTRop
  • 1 year later...
Hi James,
The GitHub page seems to be gone.   Could you or anyone else here who has that PRT ROP send it to me?  Would be much appreciated.
joescarr at gmail.com
Thanks!
  • 2 weeks later...
