dus.marjanovic Posted February 21, 2017 Share Posted February 21, 2017 Hello, trying to copy constant ID numbers from sop node to constraint points field on sbdconstraint. Info inside attached file: ---- sbdconstraint4 only matters In field "Constrained points " I want to put id numbers from OUT_POINTS_TO_CONSTRAIN that is in SOP context above. After blast, ptnum hes been changed, but @id is constant, so in my case numbers are 2,5,8,9,12,15,18,23,25 How to put those numbers procedurally in "Constraint points"? I was trying with points( "/obj/RnD/OUT_POINTS_TO_CONSTRAIN" , "@ptnum" , “id” ) and other variations but does not working. ---- Thanks RnD_CONSTRAINTS_04.hip Quote Link to comment Share on other sites More sharing options...
