Federico Posted February 22, 2017 Share Posted February 22, 2017 Hi guys! I need to slowdown a flip fluid mesh, to see if i can avoid to redo the flip simulation. I tried with a simple timewarp (from 1-500 to 1-700) but it cause a jittering in the fast moving parts. So i tried to retime my compressed particle cache using a blend node and a custom node called timedrive (from orbolt), but both fail. I guess because i have the reseeding option enabled which change the point ID. Someone has some suggestions on how slowing down a flip fluid without having to resimulate everything? Quote Link to comment Share on other sites More sharing options...
GeneralLethal Posted February 24, 2017 Share Posted February 24, 2017 Did you cache @v? Can't try this right now, but let's say: oldFrameNumber/newFrameNumber = 500/700. So your new frame 75, for example, would be old frame 53.57. You sample P at frame 53 and add 0.57 times your velocity per frame to get your position. It'll be jerky but should work despite varying id's. Quote Link to comment Share on other sites More sharing options...
Federico Posted February 24, 2017 Author Share Posted February 24, 2017 In the end i had to resimulate the flip fluid without the reseed, unpack the compressed cache and then apply the timeblend/timewarp combo. I'm curios about your method, i should still have the old cache of the meshed flip fluid (with the velocity attribute) to test it out. I have to use a point vop right? Quote Link to comment Share on other sites More sharing options...
GeneralLethal Posted February 24, 2017 Share Posted February 24, 2017 You could use a point VOP, or just timeshift to your desired length then use a wrangle node: f@frameFraction = ((@Frame - firstFrame) * (oldLength / newLength)) % 1; @P += @v * @frameFraction * @TimeInc; 2 Quote Link to comment Share on other sites More sharing options...
Federico Posted February 24, 2017 Author Share Posted February 24, 2017 Thanks i will try to test it as soon as i can. Quote Link to comment Share on other sites More sharing options...
