Problems with Upres and pyro cluster
Hartman-
I'm trying to debug why upres doesn't work when importing a pyrocluster. It looks like the upres node is only recognizing the first set of pyro cluster data being read in, i.e. the data from the pyro_0 group which would correspond to the first cluster. I can manually tell the upres node to use the different groups of data that would correspond to the other clusters (pyro_1, pyro_2, etc), but not multiple groups... only one. I have no clue how to go about reading in a pyro cluster cache so that I can upres it... I feel like this should possible in Houdini without having to setup upres nodes for each cluster in the simulation.
I've attached the most basic scene (copy sop with spheres that are the cluster points for a pyro cluster sim) that I'm using to try and get the upres to work before integrating into any other scenes.
pyrocluster_forupres.hipnc
  • 1 year later...
  • 1 year later...
