Compiling OpenVDB version4 with houdini 15.5
Meg
Hi! I am new to this forum,
I am trying to compile openVDB4.0 houdini toolkit on houdini 15.5. I have sourced the houdini setup script and managed to compile the library, the unit tests also run. The new openVDB nodes show up in houdini, but when I use the createVDB node, houdini crashes with a memory usage error. I am able to compile and execute the examples in the openVDB cookbook with version 4.
The versions of the dependencies I have used are : gnu make 3.81, and cppunit version 1.13, the rest of the libraries are as specified in the houdini HDK. Has anyone else faced the same error? Could this be an issue of version mismatch? I will update with the error log soon!
Edited by Meg
  • 6 months later...
