jumper Posted March 3, 2017 Share Posted March 3, 2017 Hi, How do I retime(time warp) an rbd object that is dynamically fractured (using the make breakable shelf tool). I have tried adding a timeblend followed by a timeshift. The timeshift has a varing animation curve (instead of $F) to vary the speed of the sim. The timeshift with interger frames on (as default) just doubles frames so that I get identicle frames instead of timestretching. If I take interger frames off I get the inbetween frames - except the geo jumps just befor the fracture. I have attached a simple setup. Is there a better way to achieve time warping with variable speed? Thanks retime_v001.hip Quote Link to comment Share on other sites More sharing options...
